PLL ICs with analog multiplier phase detectors ? Are they still around ?...
On 5/28/2023 6:41 AM, Ricky wrote:
On Sunday, May 28, 2023 at 1:12:43 AM UTC-4, bitrex wrote:
On 5/28/2023 12:10 AM, John Larkin wrote:
On Sat, 27 May 2023 21:01:32 -0400, bitrex <us...@example.net> wrote:
On 5/27/2023 7:36 PM, John Larkin wrote:
On Sat, 27 May 2023 14:48:28 -0700, boB <b...@K7IQ.com> wrote:
Is anybody making a PLL IC with multiplier input phase detector that
doesn\'t cost, like $50+ from Analog Devices ? Parts that are active
and still being manufactured ?
I used to use ones like the XR-215 and some others but have not seen
any for many years now.
The 74HC4046 is OK but not the phase detector I am looking for.
Not for microwave use. Much lower frequency than those kinds.
boB
You could make one. Use a dual comparator and an xor gate for the
multiplier.
Or a quad XOR gate to be really cheap.
Using the SLG46537 mixed-signal PLC or similar you can build a pair of
nice edge detectors with its four onboard comparators maybe sort of like
this:
https://patents.google.com/patent/EP0643484A1/en
And then with the 8 stage async state machine you can implement several
phase detector topologies, once you\'ve got edges for firing the
transitions.
I think 25 cents or so in small quantity:
https://www.renesas.com/us/en/products/programmable-mixed-signal-asic-ip-products/greenpak-programmable-mixed-signal-products/greenpak-asynchronous-state-machine/slg46537-greenpak-programmable-mixed-signal-matrix-asynchronous-state-machine
Yes, you can make a nice phase-frequency detector in an FPGA.
I think feature-rich mixed-signal FPGAs that are around the quad XOR
gate price point are pretty exciting!
FPGAs at TTL logic prices? Has TTL gone up sharply in the last year or so? Which FPGAs would this be?
Or was this sarcasm? Text medium often requires some explicit indication of sarcasm.
Some call a chip like the SLG46537 a \"micro-FPGA\", or a mixed-signal
CPLD with FPGA-like features, or whatever u wanna call it.
The analog multiplier function in figure 24 here
<https://www.ti.com/lit/ds/symlink/lm13700.pdf>
only requires half a LM13700, and some resistors.
On Sat, 27 May 2023 21:52:07 -0700, boB <boB@K7IQ.com> wrote:
On Sat, 27 May 2023 21:10:34 -0700, John Larkin
boB
multiplier.
this:
transitions.
Thanks for the suggestions.
We do already use the Silego Greenpak devices. Great parts !
This question was intended to find one like the old PLL chips that,
Like Phil Hobbs said, are all gone now. As fo the MC1496, we used to
actually use those many decades ago in an FM tuner we used to make.
The reason for the analog multiplier instead of digital comparator or
zero crossing detector is that this was going to be used for synching
to 60Hz (ish) AC grid or generator sine-waves that may very well be
distorted. Especially genny waveforms. Those do not ensure that zero
crossing is clean and detectble repeatably.
I had even looked to try and find an analog multiplier IC and those
are not availabe for cheap. Could make one out of log amps using
CD3046 transistor arrays but that is quite a few parts.
I think that the way to do this may actually be to use a cheap ARM
Cortex M0+ or similar micro with at least 2 A/D inputs and at least
some speed. 60 Hz area should work easily done with a 48 MHz
part I think. The whole PLL should be able to be done in one of these
actually. Digital filtering and all.
You are basically trying to estimate the phase and frequency of the
fundamental of a distorted signal, where the fundamental is known to
be very close to 60 Hz. This is easily done by fitting a sinewave
function to the A/D samples in a batch maybe a second or two long, so
long as the distortion isn\'t too bad. If it is bad, some added
complication is needed, such as modeling a few of the harmonics as
well.
Joe Gwinn
boB
multiplier.
this:
transitions.
Both are almost free, but the FPGA needs to be programmed.
boB
multiplier.
this:
transitions.
well.
Joe Gwinn
The multiply-and-average approach is guaranteed to work, though, and
fitting isn’t.
Because fitting emphasizes the worst outliers, it falls apart completely at
low SNR, whereas multiply+average works even with SNRs way below 0 dB.
Dr Philip C D Hobbs Principal Consultant ElectroOptical Innovations LLC /
Hobbs ElectroOptics Optics, Electro-optics, Photonics, Analog Electronics
boB
multiplier.
this:
transitions.
Yes, well, I guess we\'ll have to come up with different terminology for CPLDs (SuperFPGAs) and actual FPGAs (UberFPGAs).
The Greenpak devices are a long way from an FPGA, by any measure. I was hoping to use one on my current design as a \"sweep\" to include multiple bits of level converters and amplifiers and power regulators. Turns out while these three functions are available in their devices, no device includes even two. I was particularly disappointed that the logic level converters were not at all widely supported. I did manage to find a regulator device with simple logic functions. A significant disappointment from what I had hoped to do.
So, no, I am not remotely inclined to refer to them as any sort of FPGA. They are much more like a bit of this and that, snips and snails and puppy dog tails.
I believe Renesas is working on an actual FPGA-like device which has been in the announcement stage for some time now. Just the other day I saw that they still do not have even a preliminary data sheet as they wish to continue to \"perfect\" the design.
Oh, well.
Rick C.
+ Get 1,000 miles of free Supercharging
+ Tesla referral code - https://ts.la/richard11209
On Sun, 28 May 2023 18:04:55 -0000 (UTC), Phil Hobbs
boB
multiplier.
this:
transitions.
well.
Joe Gwinn
fitting isn’t.
True in general, but with a power source, wideband random noise isn\'t
usually the problem, it\'s waveform distortion due to the generator
design, plus power-system transients.
Which is why in practice one does some data grooming first, like
impulse clamping or blanking, if the impulses are common enough to
matter.
I would assume that a distorted waveform may also affect the imputed
zero crossing locations from multiply-and-average, at least the odd
harmonics will, but I don\'t know how important that is for the OP\'s
intended use. Probably will want to clamp the transients as well.
Joe Gwinn
boB
multiplier.
this:
transitions.
well.
Joe Gwinn
fitting isn’t.
matter.
Joe Gwinn
Nope. Multiply and average pulls out the in-phase fundamental component to
any accuracy you like (and that your digitizer can manage), while ignoring
all the harmonics to the same accuracy.
There are the usual Shannonish tradeoffs between accurate tracking of FM
and noise elimination, but you can notch out the harmonics by simply
averaging for an integer number of cycles.
Having the correct phase vs time, the same numerical oscillator code will
make a clean replica shifted by 90 degrees so as to match the fundamental
component of the input.
boB
multiplier.
this:
transitions.
well.
Joe Gwinn
fitting isn’t.
matter.
Joe Gwinn
I should say that if one is trying to lock to an edge, rather than to the
fundamental component, life does get harder and less well defined as the
SNR drops or the waveform gets gnarlier-looking, as you say.
On Mon, 29 May 2023 01:34:50 -0000 (UTC), Phil Hobbs
boB
multiplier.
this:
transitions.
well.
Joe Gwinn
fitting isn?t.
matter.
Joe Gwinn
Yes. And doesn\'t the multiply-and-average approach implicitly depend
on the full-bandwidth waveform being symmetric in time? Said another
way, would the zero-crossings of a asymmetric triangle wave be
precisely located in time?
Joe Gwinn
boB
multiplier.
this:
transitions.
well.
Joe Gwinn
fitting isn?t.
matter.
Joe Gwinn
The theorems are correct, so the phase of the fundamental can be located to
any accuracy you like, regardless of the waveform symmetry or lack of it.
Identifying phase with the position of the zero crossings becomes an
ill-defined operation very quickly as the SNR declines.
Even a DC offset will screw that up.
Joe Gwinn
On Mon, 29 May 2023 16:01:30 -0000 (UTC), Phil Hobbs
boB
multiplier.
this:
transitions.
well.
Joe Gwinn
fitting isn?t.
matter.
Joe Gwinn
Which theorems?
Yes.
What we need to know is what matters most in the OPs problem.
Joe Gwinn
boB
multiplier.
this:
transitions.
well.
Joe Gwinn
fitting isn?t.
matter.
Joe Gwinn
Which theorems?
Fourier decomposition. You derive each Fourier coefficient as the
normalized overlap integral of the corresponding eigenfunction and the
given function. The computation becomes exact as the limits of integration
go to infinity.
Cheers
Phil Hobbs
Yes.
Joe Gwinn
On Sun, 28 May 2023 07:33:13 -0700 (PDT), Anthony William Sloman
<bill.sloman@ieee.org> wrote:
On Sunday, May 28, 2023 at 11:23:22?PM UTC+10, Phil Hobbs wrote:
On 2023-05-28 00:52, boB wrote:> On Sat, 27 May 2023 21:10:34 -0700,
snip
I think that the way to do this may actually be to use a cheap ARM Cortex M0+ or similar micro with at least 2 A/D inputs and at least some speed. 60 Hz area should work easily done with a 48 MHz part I think. The whole PLL should be able to be done in one of these actually. Digital filtering and all.
If the waveform can be really gnarly, then what you want is a digital lock-in, where you multiply samples of the input by samples of a good-quality sine wave, and relying on the orthogonality of sines and cosines in both the continuous-time and sampled domains.
An analog multiplier and and analog sine wave can work just as well.
There are various way of doing that, mostly depending on whether the sampling clock is derived from a fixed-frequency oscillator or from one locked to the input. There are advantages to both.
Getting tunable clean sinewave oscillator for a phase-locked loop can be tricky. I\'ve worked out a couple of ways of doing it, but haven\'t put any of them into practice.
A well filtered Direct Digital Synthesis chip can come pretty close
Using a fixed-frequency sampling clock is simpler, and all the nice Fourier transform and DSP theorems hold exactly.
Using a phase-locked sampling clock helps keep all the sampling and slewing transients fixed, so that non-ideal behavior of the sampling system doesn\'t lead to phase modulation. (Frequency-domain applications are absolutely brutal at showing up any non-ideal behavior of your sampling system, which is why everybody seems to screw up their first digital lock-in design.)
There\'s also a lot of high frequency digital hash floating around the powers, and it takes careful design and layout to keep it out of the places where it creates problems.
Using ECL logic puts much less hash on the power rails, but that tends to be impractical.
We\'re obviously relying on the validity of the orthogonality relations in both cases, so in the variable-clock case, the tuning range has to be kept within reasonable bounds. (The math isn\'t difficult, but you do have to take some care.)
Getting the layout and right and keeping the high frequency hash away from the sensitive bits takes no less care.
Some great ideas !
My route would now be to use an inexpensive-ish ARM Cortex-M0+ most
likely. Running balls out should maybe give me two PLLs even. For $1
Don\'t need a sine-wave output. That is provided from another place.
Just need a rising or falling edge to indicate phase sync is all.
I will also have to look into what Phil was talking about.
I originally was wondering where they all are now but yes, a micro
these days can do it all and even more.
Maybe I also kind of miss the days of the old PLLs that were around.
OK, more posts below to read.
You\'re all right on here ! Thanks !
boB
On Mon, 29 May 2023 17:17:40 -0000 (UTC), Phil Hobbs
boB
multiplier.
this:
transitions.
well.
Joe Gwinn
fitting isn?t.
matter.
Joe Gwinn
Which theorems?
go to infinity.
Cheers
Phil Hobbs
Yes.
Joe Gwinn
This application is for an inverter synchronizing to grid.
We are doing this now in software both ways. Zero crossing detect and
multiplier/filtering PLL. The zero-cross method works but can be a but
jumpy once in a while. The more complicated method works better I
think but takes a lot of processor time. It CAN also become somewhat
unstable if not given the right coefficient values etc.
Since it can be computationally intensive so I was trying to see if
there might be an out of the main microcontroller\'s code space metod
of accomplishing this part, inexpensiviely. Another micro, although a
cheap micro can do this instead of an old style PLL IC.
DC offset should not be a problem. If there is DC on the grid or
generator, then the whole unit should disconnect from that AC source.
Appreciate the extra brain power from you guys.
boB
On Sun, 28 May 2023 09:39:11 -0700, John Larkin
boB
multiplier.
this:
transitions.
Programming these guys is easy enough. You can even re-program in
circuit, or, upload new circuit to its RAM via I2C if you want.
I would love it if they had one of these GPs with just gates and
flip-flops and LUTs.
We use these and they work great ! We could also replace an old
Xylinx CPLD with one if it tends to go EOL.
boB
On Sun, 28 May 2023 08:56:25 -0700 (PDT), whit3rd <whit3rd@gmail.com>
Thanks. That part number did cross my mind.
I think that a cheap ARM like JL mentioned is the way to go here.
boB
boB
multiplier.
this:
transitions.
well.
Joe Gwinn
fitting isn?t.
matter.
Joe Gwinn
Which theorems?
go to infinity.
If you tweak it wrong, it\'ll lose lock, for sure. The loop can also
oscillate while remaining in lock (more or less).
A reliable way of doing the lock detection is to do the multiplication
with both the sine and cosine components of the reference. The loop
will lock at quadrature, where the other multiplication reaches a peak.
Multiply-and-average is much better than a phase-frequency detector.
PFDs are sensitive to the number of edges, so any time you get a
spurious edge, the loop loses lock and has to reacquire. Multiplying
phase detectors and even XOR gates are much better if the signals aren\'t
squeaky-clean. An XOR doesn\'t care about transitions, just the duty
cycle of the result.
To save processor time, you could use a simple IIR filter to knock down
the harmonics a bit, and then multiply by +-1, giving the rough
equivalent of an OR phase detector with lock detection. If you pick the
coefficients cleverly, you can do it all with a few shifts and adds.
(You want to avoid thresholding the filtered signal before
XORing--otherwise junk happening near the zero crossing will get
amplified a lot.)
there might be an out of the main microcontroller\'s code space method
(The RF PLL chips weren\'t that great either.)
Cheers
Phil Hobbs
Dr Philip C D Hobbs
ElectroOptical Innovations LLC / Hobbs ElectroOptics
Briarcliff Manor NY 10510
http://electrooptical.net
http://hobbs-eo.com
boB
multiplier.
this:
transitions.
well.
Joe Gwinn
fitting isn?t.
matter.
Joe Gwinn
Which theorems?
go to infinity.
Cheers
Phil Hobbs
Yes.
Joe Gwinn
The inverter providing power to that grid, where the provided power
comes from a windmill or photovoltaic source?
How distorted is the grid power waveform? How symmetric in time? My
recollection is that the waveforms can be pretty banged-up, largely
due to the non-linearity of transformers and the fact that it takes a
log of engineering to get rotating generators to provide good sine
waves.
What is the metric we are trying to minimize? In other words, what
constitutes perfect synchronization?
I recall the old manual method used in power plants, an incandescent
lamp connected between the grid (a bunch of other generators flying in
formation) and the new candidate to fly with that flock - the metric
was when the lamp went dark. One bounced between advance and retard,
and split the difference. When the switch was closed, there would be
a transient while the flock forced the candidate to fly right.
In modern terms, how big a sync transient is permitted?
multiplier/filtering PLL. The zero-cross method works but can be a bit
Yes. Zero-crossing detectors are always jumpy in real-world
applications. Avoid them if possible. Batch methods are usually far
better behaved.
Yes.
This ought to be workable - modern micros are cheap and powerful.
Sounds right.
Thanks. It is an interesting and practical problem.
Joe Gwinn
On Tue, 30 May 2023 10:32:41 -0400, Phil Hobbs
boB
multiplier.
this:
transitions.
well.
Joe Gwinn
fitting isn?t.
matter.
Joe Gwinn
Which theorems?
go to infinity.
amplified a lot.)
Cheers
Phil Hobbs
It wouldn\'t take much of a uP to make a software quadrature DDS and do
a multiply against the digitized line waveform and use the product to
servo the DDS phase or frequency. Do that calc at some modest number
of KHz. It averages, so ignores noise and harmonics that would wobble
a zero-cross detector.
One could do a true phase - not frequency - locked loop too.
Another idea: make a software bandpass filter but turn it into an
oscillator when the line voltage fails. Just for fun; the DDS makes
more sense.
Or use a uP internal timer (most have them) and sync it with the line
frequency, and free-run when the line fails. That could be really
easy.
