M
MechaniX
Hi lahat, forum helped me a lot,
subalit ako pa rin magkaroon ng problema sa oras na ito na may Hercules:
Ko bang gamitin ang kosmos bilang layout na kasangkapan sa kanyang default demo lib.
Kapag ako tryed upang i-check ang anumang cell para sa DRC ng error ang mangyayariCode:Hercules (R) Hierarchical Design Verification, IA.32 Release B-2008.09.18103 2008/08/21(C) Copyright 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005,
2006, 2007, 2008.
Synopsys, Inc All rights reserved.Tinatawag bilang: Hercules-f MILKYWAY-i-CosmosDemo.Lib p / malambot / synopsys / kosmos / demo / Halimbawang-b nand / malambot / synopsys / kosmos / demo / Halimbawang / FTK / runsets / drc.evSa pag-parse ng runset "/ malambot / synopsys / kosmos / demo / Halimbawang / FTK / runsets / drc.ev"TANDAAN: / malambot / synopsys / kosmos / demo / Halimbawang / FTK / runsets / drc.ev: 252: PUMILI command tinanggal; ito ay walang mga kontribusyon
TANDAAN: / malambot / synopsys / kosmos / demo / Halimbawang / FTK / runsets / drc.ev: 253: PUMILI command tinanggal; ito ay walang mga kontribusyon
TANDAAN: Optimization tinanggal 2 unneeded command
TANDAAN: / malambot / synopsys / kosmos / demo / Halimbawang / FTK / runsets / drc.ev: 119: boolean command pinalitan ng KOPYA
TANDAAN: Optimization papalitan 1 utos na may KOPYA command
Paganahin ang Maramihang Hierarchy
Mon Mar 2 18:23:14 2009
EV_Engine (R) Hierarchical Design Rule checker, IA.32 Release B-2008.09.18117 2008/08/28(C) Copyright 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005,
2006, 2007, 2008.
Synopsys, Inc All rights reserved.Tumatakbo Single-Threaded codeRunset file ...................... / malambot / synopsys / kosmos / demo / Halimbawang / FTK / runsets / drc.ev
Kasalukuyang Directory ................ / malambot / synopsys / kosmos / demo / Halimbawang
Hostname ......................... localhost.localdomain
Platform uri .................... IA32_L24
MILKYWAY input ng library path ...... / malambot / synopsys / kosmos / demo / Halimbawang /
MILKYWAY input file name ......... CosmosDemo.Lib
MILKYWAY block pangalan .............. nand
LTL output library path .......... / malambot / synopsys / kosmos / demo / Halimbawang /
LTL output library pangalan .......... CosmosDemo.Lib
LTL output_block pangalan ............ EV_OUTPUT
Patakbuhin ang mga detalye ng ...................... / malambot / synopsys / kosmos / demo / Halimbawang / run_details
Group direktoryo file ............. / malambot / synopsys / kosmos / demo / Halimbawang / run_details / grupo
Panatilihin grupo ng mga file ............... matalino
Suriin ang reference structures ....... yesSimula ng isang pahina ng walang kapalit na mode Milkyway db session ...DATATYPE_OFFSET = false.
May ay walang kaibahan sa datatype
sa pagitan ng FRAM at buo views.
Magpasok ng Library Format: 127 magpasinda cellnames
Output Library Format: Walang output library
Nire-render ang 'pmos' Programmable cell
iligal na katangian Pangalan (datatype) para sa mga uri ng [155]
iligal na katangian Pangalan (layer) para sa mga uri ng [155]
iligal na katangian Pangalan (routeType) para sa mga uri ng [155]
iligal na katangian Pangalan (netId) para sa mga uri ng [155]
iligal na katangian Pangalan (flags) para sa mga uri ng [155]
iligal na katangian Pangalan (bbox) para sa mga uri ng [155]
iligal na katangian Pangalan (points) para sa mga uri ng [155]
iligal na katangian Pangalan (numberOfPoint) para sa mga uri ng [155]
Tcl Error: Disenyo tuntunin 2 minEnclosure 3 hindi natagpuan
BABALA: bigo sa render pcell object 'pmos'
Nire-render ang 'nmos' Programmable cell
BABALA: bigo sa render pcell object 'nmos'
Fatal error # 708: Hindi mabuksan ang file na istraktura "_nmos_db0137c0" para sa pagbabasa. Aborting.
Lumabas Hercules!
Hercules Run: Oras = 0:00:05 User = 0,78 System = 0.19
Hercules ay tapos na.
2006, 2007, 2008.
2006, 2007, 2008.
Lumabas Hercules!
